Enclosure
My kit just arrived in Denver Colorado USA! I assume the Solar panel connects to the green terminals directly? I also assume it will help charge the battery by day so it will run at night?
Where is the .stl file for the 3D enclosure so I can print one?
Excited to share and engage…
Hi! We will post the files next week. Take in account that they will not be final final designs, but we expect people to use them and customise them. Great you are enjoying using the kit!
Hi, where can I find the files? Are they been posted?
Hi @Stebar59!
You can find the files for the enclosure here: http://www.thingiverse.com/thing:236976.
If you are using the enclosure with a Solar Panel you will have to add a hole for the wiring.
Best.
:slight_smile:
Thanks for the quick answer! In the mean time I had found the files on Thingiverse :slight_smile:
+1
