Fitting the kit into the gray box
Hello
I finally got the SCK setup after several attempts (switching between different PCs including Ubuntu) but in the end went with Windows XP. It does all seem to be working now. However I have little gray box for the enclosure which may work find but there is no way I can connect the battery to the board and have it fit into the box.
Any updates on when other cases will be made available?
regards
Robin
Hello Robin
glad you got your kit working. About the case: it should fit, we had the issue with the polarity of the battery which caused to put extra solder, but if you bend a bit it should fit, even if is too tight. Here are the files of the enclosure: http://www.thingiverse.com/thing:236976 we encourage people to download it and modify as they want.
Another option is to use a standard electrical box, in Amsterdam is being done: http://www.elektrobode.nl/spelsberg-tk-ps-99-6-tm-lege-behuizing-10600301.html?utm_source=beslistslimmershoppen&utm_medium=cpc&utm_campaign=beslist&utm_content=discarded
Hope this helps
Tomas
Robin,
See if this helps. http://forum.smartcitizen.me/discussion/328/enclosure-modification
Chris
