How to set location - latitude and longitude
I managed to set my first device 969 to my exact location at a bend in a footpath. I want to set a second sensor to the exact same location. Using postcode is not exact enough. When I click on the map and choose Save, the sensor’s location is not updated. Please advise.
I’ve realized the same issue as you. It kind of prevents user manually input a wrong location information. However, the accuracy of location is compromised.
Hi @cfrench and @yulinwu. Thanks a lot for your comments about this issue and sorry for the late response. We have already fixed the problem with the geolocation system and now you should be able to click on the map to choose your exact location and also use the auto-complete tool. Please, let us know if it works well for you now. We really appreciate your support. All the best.
