My kit does not post data to server and does not connect to internet
My kit does not post data to server and does not connect to internet.
I can see data in the Arduino Serial Monitor:
Temperature: 28968 C RAW
Humidity: 14132 % RAW
Light: 1.30 lx
Battery: 97.70 %
Solar Panel: 0 mV
Carbon Monxide: 443.52 kOhm
Nitrogen Dioxide: 15.37 kOhm
Noise: 67 mV
Wifi Spots: 0
UTC: 2016-02-16 20:50:19
In CMD, after reboot command:
<4.41> reboot
RebootWifly-GSX Ver: 4.41 Build: r1057, Jan 17 2014 10:26:26 on RN-131
MAC Addr=00:06:66:36:9d:62
READY
Auto-Assoc guest chan=11 mode=MIXED SCAN OK
Joining guest now…
Associated!
DHCP: Start
DHCP in 4897ms, lease=86400s
IF=UP
DHCP=ON
IP=192.168.168.201:2000
NM=255.255.255.0
GW=192.168.168.254
Listen on 2000
<4.41> get wlan
SSID=guest
Chan=0
ExtAnt=0
Join=1
Auth=MIXED
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=30
Passphrase=xxxx
EAP_Id=userid
EAP_User=peap-user
<4.41> show t t
Time NOT SET
UpTime=152 s
RTC=153
Restarts=1
Wake=1
RAW=4cbfe5
<4.41>
get mac
Mac Addr=00:06:66:36:9d:62
<4.41> show connection
8b30
<4.41> show net
SSid=guest
Chan=11
Assoc=OK
Rate=12, 24Mb
Auth=OK
Mode=MIXED
DHCP=OK,renew=64289
Boot=5048
Time=FAIL
Links=1
<4.41> show rssi
RSSI=(-40) dBm
<4.41> show stats
Conns=0, WRX=0/0, WTX=0/0, RTRY=0, RTRYfail=0
URX=17, UTX=1341, RXdrop=0, RXerr=0,
FlwSet=0, FlwClr=0
TX-UDP=0, netbufs=0, evt=0, adhoc_lost=0
Boots=1, Wdogs=0,TXon=1
What else should I try?
No reply from support.
P.S.: How can I delete one kit from my web portal account?
Hello @smartiot,
Your kit is properly registered. I will suggest you to repeat the setup process and upload the firmware again (Click on the settings gear icon and the SETUP)
https://smartcitizen.me/profile/kits
You can delete a device by scrolling down on the kits page you will find the delete options
https://smartcitizen.me/kits/3107
Please, report here or on support@smartcitizen.me any other issues.
We also improved the documentation, hope this helps.
http://docs.smartcitizen.me/#/
