Solar Panel not providing enough power?
Hi guys,
seems like my solar panel is unable to recharge the battery, or either compensate the power consumption by the device.
Since there’s direct light exposure to the panel, I’m wondering if I should reduce the measurement frequency (or either the upload frequency for collected data).
Is there any best practice for those values, or do you have any other explanation for my device behavior?
You can check the actual reading at this URL: http://j.mp/1lOlCsj
Thanks in advance for your precious help
Hi @UMMgl! Sorry for the late response. With direct light exposure to the panel, you should be able to charge the battery without reducing the default measurement frequency (despite it can help). In any case, the battery load capacity is directly related the amount of hours the panel is exposed to sunlight. Although the power consumption issue must be reviewed, if your solar panel is unable to recharge the battery or compensate the power consumption by the device, this means the sunlight exposure is not enough. Where are you based!? All the best.
Thanks for your feedback @aitoraloa .
The updated URL for my sensor is http://smartcitizen.me/devices/view/1234
It’s located at these coordinates: 45°18’37.3"N 11°57’17.6"E
You are right - there’s no limited light exposure right now since I’ve not enough wireless signal under the roof (where I wish I could store my appliance)
I’ll try to find out a better location for my kit!
Thanks a lot guy!
