Blinking Blue Light
Hi here,
We have some devices (SC v2.2) that stop sending information and have blue blinking lights. The wifi network is however perfect and when linking the device to the Arduino IDE via USB it is not recognized by the IDE, (no USB port found). It appears the device is frozen (apart from the blue blinking lights).
We have to reset the device to be able to use the Serial Monitor again (usb port comes available) and then it can perfectly use the wifi again.
Does anyone recognize this behavior?
Thanks in advance,
Dimitri
Hi @dimitri
It is possible that the device was frozen at that moment. Does it happen frequently, or right after it tries publishing data?
If you can, send us some logs on the Serial monitor. If you are able to reproduce the issue, that would be very helpful.
Hi @oscgonfer,
Thanks for the reply!
It happens frequently, I now have 2 devices that hang, last ERROR.txt entry is
2026-02-13T16:16:46Z–>ERROR: Publish failed, will retry on next interval!!!
2026-02-13T16:58:33Z–>ERROR: MQTT publish failed!!
2026-02-13T16:58:33Z–>ERROR: Publish failed, will retry on next interval!!!
2026-02-13T16:58:47Z–>ERROR: MQTT publish failed!!
2026-02-13T16:58:47Z–>ERROR: Publish failed, will retry on next interval!!!
And then they stop doing anything, I have to restart them to be able to read the serial monitor.
Will put both in debug mode to have debug information on the SD card before they hang.
Kind regards,
Dimitri
Hi @oscgonfer,
On one device I had activated the sdcard debug already, this was found:
2026-02-18T15:00:34Z–>ERROR: MQTT publish failed!!
2026-02-18T15:00:34Z–>ERROR: Publish failed, will retry on next interval!!!
2026-02-18T15:00:34Z–>ESP off…
2026-02-18T15:00:35Z–>SEN5X PM 2.5: 2.50 ug/m3
2026-02-18T15:00:35Z–>SEN5X PN 1.0: 1560.00 #/0.1l
2026-02-18T15:00:35Z–>SEN5X Typical Particle Size: 68.40 um
2026-02-18T15:00:35Z–>it’s time to publish
And then nothing, until I performed a reset:
2026-02-20T17:11:57Z–>Card size: 15978 MB
Volume is FAT 32, Cluster size (bytes): 32768
2026-02-20T17:11:57Z–>Sd card ready to use
2026-02-20T17:11:57Z–>Saved INFO.TXT file!!
2026-02-20T17:11:57Z–>Turning on WiFi…
2026-02-20T17:11:58Z–>ESP finished booting
2026-02-20T17:11:58Z–>Saved INFO.TXT file!!
Many thanks,
Dimitri
Hi @dimitri
I’d suggest to try the following:
flash
This will output the current status of the flash memory. Let’s see if the analysis goes well.
If it hangs, then do:
flash -format
This will erase the external flash memory in the module, which contains readings for the last 70ish days. Let’s see if that does it.
Hi @oscgonfer ,
Thanks, flash works, have included the output:
Kind regards,
Dimitri
flash
Scanning Flash memory (it can take a while!)
0 > |u49(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|
32 > |u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u51(_/_)|u47(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u50(_/_)|u49(_/_)|u48(_/_)|u49(_/_)|u48(_/_)|u49(_/_)|u48(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|
64 > |u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u51(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u51(_/_)|
96 > |u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u51(_/_)|u50(_/_)|u51(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|
128 > |u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u48(_/_)|u46(_/_)|u49(_/_)|u48(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|
160 > |u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|
192 > |u50(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u49(_/_)|u50(_/_)|
224 > |u49(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u51(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|
256 > |u50(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u51(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|
288 > |u49(_/_)|u49(_/_)|u47(_/_)|u48(_/_)|u46(_/_)|u47(_/_)|u47(_/_)|u46(_/_)|u48(_/_)|u47(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u48(_/_)|
320 > |u48(_/_)|u49(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u47(_/_)|u47(_/_)|u48(_/_)|
352 > |u47(_/_)|u48(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|
384 > |u50(_/_)|u50(_/_)|u48(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u49(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|
416 > |u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u47(_/_)|u48(_/_)|u46(_/_)|u48(_/_)|u48(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u47(_/_)|u48(_/_)|u48(_/_)|
448 > |u49(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|
480 > |u49(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u48(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|
512 > |u49(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u48(_/_)|
544 > |u48(_/_)|u48(_/_)|u48(_/_)|u48(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u48(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|
576 > |u50(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u48(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u49(_/_)|u47(_/_)|
608 > |u48(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u46(_/_)|u46(_/_)|u47(_/_)|u47(_/_)|u47(_/_)|u48(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|
640 > |u49(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u48(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|
672 > |u48(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u49(_/_)|u47(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|
704 > |u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|
736 > |u49(_/_)|u49(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u51(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u51(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|
768 > |u48(_/_)|u48(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u48(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|
800 > |u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u49(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u48(_/_)|u47(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u48(_/_)|
832 > |u48(_/_)|u49(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|U16(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|
864 > |u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u48(_/_)|u50(_/_)|
896 > |u50(_/_)|u48(_/_)|u47(_/_)|u47(_/_)|u48(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u47(_/_)|u48(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u47(_/_)|u47(_/_)|
928 > |u47(_/_)|u47(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u51(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u51(_/_)|u51(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|
960 > |u47(_/_)|u48(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u51(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u49(_/_)|u49(_/_)|
992 > |u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|
1024 > |u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u47(_/_)|u47(_/_)|u48(_/_)|u46(_/_)|u48(_/_)|u47(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|
1056 > |u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u51(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|
1088 > |u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u48(_/_)|u47(_/_)|u46(_/_)|u47(_/_)|u47(_/_)|u46(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|
1120 > |u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u47(_/_)|u47(_/_)|u47(_/_)|u46(_/_)|u47(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u48(_/_)|
1152 > |u50(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u46(_/_)|u47(_/_)|u47(_/_)|u46(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|
1184 > |u50(_/_)|u50(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u46(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|
1216 > |u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u47(_/_)|u46(_/_)|u46(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u51(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u48(_/_)|
1248 > |u49(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u51(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u51(_/_)|u51(_/_)|u51(_/_)|u50(_/_)|u51(_/_)|u51(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u47(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|
1280 > |u48(_/_)|u47(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u51(_/_)|u51(_/_)|u51(_/_)|u51(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u47(_/_)|u47(_/_)|u48(_/_)|u48(_/_)|u48(_/_)|u48(_/_)|u47(_/_)|
1312 > |u49(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u49(_/_)|u50(_/_)|
1344 > |u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u51(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u51(_/_)|u51(_/_)|u51(_/_)|
1376 > |u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u48(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|
1408 > |u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|
1440 > |u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|
1472 > |u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u47(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|
1504 > |u50(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u48(_/_)|
1536 > |u48(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u49(_/_)|u47(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u47(_/_)|u46(_/_)|u47(_/_)|
1568 > |u47(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u51(_/_)|u51(_/_)|u51(_/_)|u51(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u47(_/_)|u48(_/_)|
1600 > |u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|
1632 > |u49(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u51(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|
1664 > |u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|
1696 > |u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|
1728 > |u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u47(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|
1760 > |u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u51(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|
1792 > |u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u49(_/_)|u51(_/_)|u49(_/_)|u49(_/_)|u51(_/_)|u49(_/_)|u50(_/_)|u50(_/_)|u51(_/_)|u48(_/_)|u50(_/_)|u50(_/_)|
1824 > |u49(_/_)|u50(_/_)|u49(_/_)|u50(_/_)|u51(_/_)|u50(_/_)|u51(_/_)|u55(_/_)|u58(_/_)|u58(_/_)|u54(_/_)|u59(_/_)|u56(_/_)|u56(_/_)|u55(_/_)|u56(_/_)|u58(_/_)|u56(_/_)|u56(_/_)|u55(_/_)|u57(_/_)|u55(_/_)|u55(_/_)|u52(_/_)|u49(_/_)|u50(_/_)|u53(_/_)|u51(_/_)|u52(_/_)|u50(_/_)|u52(_/_)|u54(_/_)|
1856 > |u52(_/_)|u59(_/_)|u58(_/_)|u60(_/_)|u58(_/_)|u58(_/_)|u58(_/_)|u60(_/_)|u58(_/_)|u57(_/_)|u58(_/_)|u55(_/_)|u56(_/_)|u57(_/_)|u58(_/_)|u57(_/_)|u55(_/_)|u54(_/_)|u59(_/_)|u60(_/_)|u59(_/_)|u60(_/_)|u59(_/_)|u59(_/_)|u58(_/_)|u57(_/_)|u57(_/_)|u59(_/_)|u59(_/_)|u58(_/_)|u58(_/_)|u53(_/_)|
1888 > |u52(_/_)|u56(_/_)|u57(_/_)|u59(_/_)|u59(_/_)|u55(_/_)|u55(_/_)|u55(_/_)|u56(_/_)|u54(_/_)|u56(_/_)|u57(_/_)|u56(_/_)|u56(_/_)|u60(_/_)|u58(_/_)|u58(_/_)|u56(_/_)|u56(_/_)|u55(_/_)|u57(_/_)|u58(_/_)|u58(_/_)|u58(_/_)|u55(_/_)|u57(_/_)|u57(_/_)|u58(_/_)|u58(_/_)|u56(_/_)|u58(_/_)|u57(_/_)|
1920 > |u59(_/_)|u58(_/_)|u60(_/_)|u59(_/_)|u56(_/_)|u56(_/_)|u57(_/_)|u56(_/_)|u54(_/_)|u58(_/_)|u58(_/_)|u60(_/_)|u56(_/_)|u58(_/_)|u58(_/_)|u57(_/_)|u58(_/_)|u59(_/_)|u57(_/_)|u58(_/_)|u57(_/_)|u58(_/_)|u56(_/_)|u56(_/_)|u50(_/_)|u47(_/_)|u48(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u48(_/_)|
1952 > |u50(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u49(_/_)|u47(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|
1984 > |u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u48(_/_)|u47(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|
2016 > |u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u47(_/_)|u48(_/_)|u47(_/_)|u48(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|u48(_/_)|u48(_/_)|u49(_/_)|
Sector state:
u -> Used sector
U -> In use sector
e -> empty sector
Readings are shown after sector state in the form of: total(net-pending/sd-pending) (ej. |u78(65/45)|)
2040 sectors in total, 2039 used and 1 free.
100758 groups in total.
Network: 0 pending to publish.
Sd-card: 0 pending to publish.
Using sector number: 854
Hi @dimitri
I think it’s suspicious that we are in the last sector and that you are getting this behaviour.
Can you do:
flash -format
Hi @oscgonfer,
Thanks, performed this:
flash -format
Formating… be patient, don’t turn off your kit!
Flash memory formated OK, please power cycle your kit. (not just reset)
SCK >
And have power cycled the kit by unplugging the battery and usb cable for more than 30 seconds. It’s sending information as we speak, will keep an eye on the behavior.
Kindest regards,
Dimitri
Great @dimitri
Please, do let us know if it works well.
Uptil now all seems ok. Many thanks @oscgonfer
Hi, @oscgonfer,
It unfortunately happened again, this whilst I performed the instructions:
last entry in DEBUG.txt:
2026-04-22T23:35:56Z–>
2026-04-22T23:35:56Z–>2026-04-22T23:35:56Z
2026-04-22T23:35:56Z–>Temperature: 22.30 C
2026-04-22T23:35:56Z–>Humidity: 43.50 %
2026-04-22T23:35:57Z–>Battery: 100 %
2026-04-22T23:35:57Z–>SD card: 1 Present
2026-04-22T23:35:57Z–>Light: 0 lux
2026-04-22T23:35:57Z–>Noise dBA: 26.97 dBA
2026-04-22T23:35:57Z–>LPS33 Barometric pressure: 102.89 kPa
Last entry in ERROR.TXT:
2026-04-22T23:35:00Z–>ERROR: MQTT publish failed!!
2026-04-22T23:35:01Z–>ERROR: Publish failed, will retry on next interval!!!
2026-04-22T23:35:12Z–>ERROR: MQTT publish failed!!
2026-04-22T23:35:12Z–>ERROR: Publish failed, will retry on next interval!!!
2026-04-22T23:35:27Z–>ERROR: MQTT publish failed!!
2026-04-22T23:35:27Z–>ERROR: Publish failed, will retry on next interval!!!
2026-04-22T23:35:41Z–>ERROR: MQTT publish failed!!
2026-04-22T23:35:42Z–>ERROR: Publish failed, will retry on next interval!!!
2026-04-22T23:35:56Z–>ERROR: MQTT publish failed!!
2026-04-22T23:35:56Z–>ERROR: Publish failed, will retry on next interval!!!
Wireless was constantly stable, the device just blinks constant blue, connects to the Arduino IDE but does not respond to commands.
Thanks in advance,
Dimitri
last entry in
And entry in INFO.TXT:
{^M
“time”: “2026-04-22T03:00:06Z”,^M
“hw_ver”: “2.2”,^M
“id”: “BE47620F5030524E572E3120FF10202B”,^M
“sam_ver”: “0.9.8-3b44c5a-dev”,^M
“sam_bd”: “2024-02-29T12:44:35Z”,^M
“mac”: “EE:64:C9:E1:9E:AE”,^M
“esp_ver”: “0.9.8-a01e3bc-dev”,^M
“esp_bd”: “2023-11-14T18:29:48Z”,^M
“rcause”: “SYST”^M
