Hi all,
Does anyone know where to find the full dimensions of the SCK 2.1 kit. Yes I know I could get a ruler out and measure, but surely there should be some manufacturing details with the exact measurements.
thanks
Andy
Hi all,
thanks
Andy
Hi @smartcitizen1!
Yes, we have uploaded them in the enclosures repo:
You will find an STL and a drawing in pdf.
Hope it helps you make your enclosures! Also, we have uploaded some designs as well, check them out in the repo!
That is awesome,
Now to nick some time with the 3D printer at work
Printer found, so will post some pictures of the finished enclosure when the R&D guys have printed out the parts.
Andy
Amazing! We are looking forward to seeing the results!
Ok first print
A little work maybe required, but nearly there.
I need to get the printing guys to look at the size of the gap of for the particle sensor, as it isnt fitting through the holder, and maybe the height of the bracket in general as it seems very tight on the sckboards.
The top has come out really nice and fits well.
I will update when I get the next print
Andy
That looks amazing Andy!!
Thanks for sharing
Hi guys,
A few tweaks (I will find out what my 3D printing friend has done) but the board and the PM Sensor fit absolutely perfectly now
Here is a bit of a photoshoot of the finished article.
Im in the process of builing my solar powered Sensor. For this project, I need more space in the case you’ve designed (make it 2,5cm more in height). I’ve tried to modify the stl files, but that doesnt work.
Would it be possible to send me the CAD files? This would allow me to proceed in the project. I can also send you the new stl file if someone else needit.
Thanks in advance!
Best regards from switzerland!
Martin
Cool work!
You can find the STL model of all the SCK 2.1 sensor components and PCBs in the enclosures repository
You can also download the PCB Design files in EAGLE (it’s free) and export the layout in any format you need
The STL Files are, unfortnuately, not enough. I cannot modify them - I would need access to the original CAD Files.
What software are you using? Would IGES fileformat work for you?
I will put them in the repository once I can access them.
Regards
Solidworks. I think iges is ok. Thank you in advance!
Just added the iges files. This is the commit:
Let me know if this worked!
Regards
Unfortunately, it doens’t work. I cannot open iges in Solidworks or creo. Do you have the files in another format?
Hey,
I just added STEP files, I think that should work. let us know!
It worked! The case is now beeing printed!
Great! Share it here and if you want, open a pull request and we will include it in the enclosures repository!
I’ve created a pull request with the modified file.
