I’ve used chocolatey to install Python 3.11 and I’ve installed the packages listed here:
https://docs.smartcitizen.me/Guides/firmware/Edit%20the%20Firmware/#installing-python
However, when I run python make.py build sam -v or python make.py build esp -v, I get an error saying that I need platformio 6 (code output is below).
I’ve uninstalled Python 3.11 and installed Python 3.9 instead, but I got the same error.
I’ve run pio and platformio in the command line, and both commands are recognised.
My OS is Windows 11 and I’m using Cygwin version 3.3.6-341.x86_64 for the command line.
Code output:
$ python make.py build sam -v
Error: Please upgrade to the PlatformIO Core 6
Traceback (most recent call last):
File "C:\HDD\WeCount\AirPollution\smartcitizen-kit-21\make.py", line 53, in <module>
kit = sck.sck()
File "C:\HDD\WeCount\AirPollution\smartcitizen-kit-21\./tools\sck.py", line 56, in __init__
self.paths['pioHome'] = [s.split()[1].strip(',').strip("'") for s in subprocess.check_output(
File "C:\Python311\Lib\subprocess.py", line 465, in check_output
return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
File "C:\Python311\Lib\subprocess.py", line 569, in run
raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command '['pio', 'run', '-t', 'envdump']' returned non-zero exit status 1.
$ python make.py build esp -v
kit = sck.sck()
$ platformio --version
PlatformIO Core, version 5.1.1
