Dear fellow smartcitizens,
We’ve had our unit up and running for about a week in Stockholm, Sweden, you can easily see from the reading that it was kept indoors for a day or so we configured it and placed in a makeshift weatherproof box outside (changed the setting to outdoor at that time as well) - with enough holes in the bottom to get some circulation, but still protected from the weather Gods. Here it is: http://smartcitizen.me/devices/view/530
As you can see, the temperature is a bit higher than normal Swedish thermometers - have three digital ones around the building and they agree on 3 ±0.5 degrees lower temperature than the sensor device does.
Humidity is about 97%, the device offers a reading about 60%
Co is on 330 kOhm - how many ppms does this convert into? is it high or low?
No is about 17 kOhm - how many ppms is that?
As for sound, the lowest read value is truncated at 50 dB, right? I had 54 dB max while I was fiddling with the installation, but since then it seems stuck on 50.
best regards
Alex
