Code refactoring
I’m recoding the firmware to save memory.
I need to understand the aim of debug mode and the terminal mode (serial command ###)
When you enter the command ###, what do you expect the SCK to do ?
It seems it stops sending data to the server.
When debugON is true, what is it expected ?
OK thanks !
It’s a little bit confusing because when debug is ON you should except to have more debug traces.
There’s another variable : terminal_mode.
So, If well understood : ### command stops debug traces and some more if checking debugOn.
And it seems sensor mode is also set to OFFLINE : it stops to read sensors too.
if the SCK is sleeping, it should respond only to the 2 following commands :
SCK commands mode
$$$ WiFly commands mode
Nothng else ?
You can check the SCK (SmartCitizenKit) commands here:
That particular command:
Wake up the module and enter SCK commands mode
Here is the line that does that:
When debugOn is true, the kit should minimize output to the serial port so you can send commands without being interrupted.
