I had an issue fitting the SCK into the 3D printed enclosure while the battery was plugged in. While there is a groove / inset to allow for the wires to go against the side, the groove misaligns with the battery connector by 2-3 cm. I ended up having to grind part of the #D enclosure down with a dremel in order to get it to fit nicely. http://i.imgur.com/9BZ5jDG.jpg
Unfortunately, I did not take a before picture, but if you look at the after picture, you can still see a little lip on the top of the marred area that shows that the edge of the inset hits the middle of the connector.
If you rework the 3d printing, I’d also suggest adding a grove & a hole for the solar panel connection. I had to string the cables through the mounting holes of the board to make it work.
Once again, thanks a lot for your feedback
