Firewall Requirements
I’m trying to install an SCK in an educational setting where they are cautious about external devices on their network. Can I confirm what is needed from a firewall perspective:
  • What is the IP/address of the endpoint that data is sent to?
  • Is it TCP or UDP?
  • What is the port number at the endpoint (80? 443?)
  • Is any access required into the device from the outside?
Thanks in advance,
jonny
Hi Johnny,
I had the same issue at my University. We have a protocol for adding media devices (like Roku and Apple TV). All that was required was the MAC address of the device. It wasn’t as straightforward as a typical Roku setup, but with IT help, I was able to add it to the network in short order. I then took the device to another building (same University network) and it connected right away.
Once it’s connected to the network, it will begin sending data directly to https://smartcitizen.me/kits/.
Good luck!
Anne
Here a bit more info
https://docs.smartcitizen.me/_FAQ/#i-have-a-firewall-what-do-i-need-to-know
thanks - that’s what I needed
