Help Needed: Removing the Smart Citizen Kit from the Outdoor Enclosure
Hey everyone,
I received an assembled outdoor sensor kit along with two indoor sensor kits. While working with the indoor kits, I was able to understand how everything works, make the necessary connections and get them running.
However, with the outdoor kit, I realised that the enclosure does not open sufficiently to provide enough space to access the components and make the necessary connections.
The most practical approach seems to be to temporarily remove the sensor kit from the enclosure, make the connections, complete the setup and activation, and then place it back inside.
The challenge is that I am unable to figure out how to safely remove the sensor kit from the enclosure, as it appears to be firmly secured in place, as shown in the attached image.
Could someone please guide me on how to:
- Safely remove the sensor kit from the outdoor enclosure without damaging any components.
- Access the components and make the necessary connections for setup and activation.
- Secure the kit back inside the enclosure while maintaining its weatherproofing.
Any instructions, reference images or videos demonstrating the process would be greatly appreciated.
Thanks in advance for your help!
