After having installed my SCK next week, I got a problem with pression and humidity always getting 50°C and 100% humidity.
As requested, I updated my SCK with the last release.
Now i got this in my arduino
Temperature: 27452 C RAW
Humidity: 21892 % RAW
Light: 210.0 lx
Battery: 70.0 %
Solar Panel: 0 V
Carbon Monxide: 363.649 kOhm
Nitrogen Dioxide: 8.506 kOhm
Noise: 47 mV
Wifi Spots: 0
UTC: 2000-01-01 00:18:51
FIRST PROBLEM :
In my first setup, I found between 9 and 12 wifi spotted, now, nothin.
SECOND PROBLEM :
When adding my sensor to the network, I don’t have any problem.
But when I try to configure it, when I click on "start process’, i got the following logs :
✓ Checking your Smart Citizen Kit version. This could take a while, please wait.
✓ Your kit is running an older firmware. This is not the latest firmware.
✓ Press Upload Firmware to upgrage the firmware of your Smart Citizen Kit
Then I select my version (1.1) and click on “upload firmware” and I got the following result after 3 attemps :
✓ Firmware update failed! Could not upload sketch to your Smart Citizen Board. Try unplugging your Smart Citizen Kit and connecting it again. Retrying 2 of 2.
✓ Trying Smart Citizen Kit auto-reset. If it does not reset automatically please reset the Smart Citizen Kit manually!
✓ Firmware update failed after 3 attempts. Please, reset your kit or try to upload the firmware manually. More info
The first time I registered and configured my sck, I don’t had any problems and I configured the wifi successfully.
So, How can I solve those problemes ?
Can someone help me please ?
PS : I checked my SCK with the check script and all was ok.
