Is Adafruit ICE Debugger Needed?
I am about to purchase Kit V2.1 from Seeed. I have read thru documentation but I am uncertain if I also need to get an AdaFruit ICE Debugger/Programmer, for purpose of reflashing.
I understand that both processors by default have been flashed, but I guess reflashing might be needed sometime.
Its an extra $AUD160 so I don’t want to purchase if its unnecessary.
If its necessary (ever), its convenient to get it now.
Also, if its necessary, which version do I need, basic model or standard model (with extra connectors).?
Please can I be advised about this.
Hi @bryn.parrott!
No, the ICE is just needed to flash the bootloader the first time or to implement complex debugging functions.
Updating the Kit firmware to a newer version or a customized version created by you only requires a computer with USB connection.
https://docs.smartcitizen.me/Guides/Update%20the%20firmware/
For more info on the use of a debugger with the Kit, you can read the following guide.
https://docs.smartcitizen.me/Guides/Debug%20the%20firmware/
Well hopefully Seeed did not forget to flash the device for me so I don’t need it. Cheers
