Is there local API?
Hi, I’m interested in the SCK 2.3. Is there a local API on the device that I can use for home Assistant/Hubitat without having to go through the internet?
Hi @christian.busch
You can change the MQTT broker on the SCK, and then ingest that data into your own setup. I believe this is fairly straightforward although i have never done so myself: MQTT - Home Assistant
This script by @pylonsoft is an example of how this setup can be done. He sends data to the public broker, but you can do the same pointing it to another broker(s) too: Add script for republishing MQTT data to public server by pylonsoft · Pull Request #427 · fablabbcn/smartcitizen-api · GitHub
If you make this work, it’d be great to hear about the results.
I was hoping to get by without having to run a MQTT broker…
Sorry. I think in previous versions this was an option, but it was removed for simplicity.
