I’m having problems.
Currently running Ubuntu 12.04 LTS, Kernel 3.2.0-58, Java version 1.7.0_51, IcedTea 2.4.4, and Firefox 26.0.
When I log into the dashboard and go through the process of adding a sensor, and then selecting the configure sensor button, I get a java error message that says;
Application Blocked by Security Settings
Your security settings have blocked a self-signed application from running.
After I click ok, the Java displays another message
The application cannot be run.
http://www.java.com/en/download/help/jcp_security.xml
I open Jcontrol and select the security tab and change the security setting from High to Medium. I then add site to the site list http://smartcitizen.me/devices/configure/556. Even after I make these changes its still not allowing me to install and run the java self-signed app.
What am I missing? Is there a signed certificate I need?
http://www.java.com/en/download/help/appsecuritydialogs.xml
http://www.java.com/en/download/faq/exception_sitelist.xml
