Kit not working. No way to get the red light back to reconfigure the kit
I was able to configure the wifi and everything went well, just for the first day. From then on it is not working. I can’t get the red light on in order to reconfigure the kit. A blue light is always blinking. I have tried to reset it pressing the button over 15 seconds. Nothing new happens. What can I do?
Your help is appreciated
To fix that, take into account that there are to buttons. One is a reset (soft), which only turns the kit off-on. The other one does a hard reset, settting the kit to factory configuration.
Sorry, wanted to say TWO buttons.
Thanks for writing to the forum!
By pressing the ON/OFF button you should be able to switch from network mode (blue) to setup mode (red).
https://docs.smartcitizen.me/Smart%20Citizen%20Kit/#the-button
If nothing works fine I will suggest you do a full factory reset
https://docs.smartcitizen.me/Troubleshooting/#troubleshooting
and restart again the configuration process
https://docs.smartcitizen.me/Smart%20Citizen%20Kit/#installation-instructions
