My kit is Private!
For the last two days my kit has been set as Private.
I didn’t set it up. Please, how can I return to not private?
Hi @t94cw !
Is this the kit: 15156? I’m checking in the API and it seems normal.
hello
yes 15156 and i get map and it says device not found or has been set to private. i have to loging to get device on the screen.also, under E73CW jn93fu it says PRIVATE in red
This is an issue on our end (not just on your kit)! Working on it to solve it!
ok, I can also tell you that when mine became PRIVATE I looked at some others on the map and they worked ok. Right now I’m looking at the same ones and they don’t work now. So they stopped after mine.
happy work
Should be solved now! Please check!
yes , it is ok .
thanks for the quick reaction.
no worries! sorry for the hassle!
