Is it possible to create a specifical alert for a particular sensor (i.e. when the temperature drops below 25ºC or when PM2,5 reaches 25 ppm)?
Ferran
Ferran
Not at the moment via the website. But you could create your own shell script to query the API every X minutes and parse the values.
Example:
cronjob on a linux server to call the script every X minutes or hour.curl to get the data.Quick example you can try in a terminal:
curl https://api.smartcitizen.me/devices/5353 | jq '.data.sensors[2].value'
