Good evening!
Finally my SCK 2.1 arrived. I put all together, update the firmware of both SAM and ESP (SAM 0.9.8 and ESP 0.9.8) but my PM sensor is always reading 0.0 (in the 3 particle dimensions)
I have done the “debug” with the shell:
02:09:10.405 -> -----------
02:09:10.405 -> 2021-10-26T01:09:11Z
02:09:10.405 -> Temperature: 22.38 C
02:09:10.405 -> Humidity: 64.92 %
02:09:10.405 -> Battery: -1 %
02:09:10.517 -> Light: 107 Lux
02:09:10.775 -> Noise dBA: 28.06 dBA
02:09:11.184 -> Barometric pressure: 101.33 kPa
02:09:11.184 -> VOC Gas CCS811: 0.00 ppb
02:09:11.241 -> eCO2 Gas CCS811: 400.00 ppm
02:09:11.241 -> -----------
02:09:11.295 -> (2021-10-26T01:09:11Z) Readings saved to flash memory.
02:10:10.531 ->
02:10:10.531 -> -----------
02:10:10.531 -> 2021-10-26T01:10:11Z
02:10:10.531 -> Temperature: 22.33 C
02:10:10.646 -> Humidity: 65.13 %
02:10:10.646 -> Battery: -1 %
02:10:10.646 -> Light: 107 Lux
02:10:10.939 -> Noise dBA: 39.00 dBA
02:10:11.348 -> Barometric pressure: 101.34 kPa
02:10:11.422 -> VOC Gas CCS811: 0.00 ppb
02:10:11.422 -> eCO2 Gas CCS811: 400.00 ppm
02:10:27.532 -> PM 1.0: 0 ug/m3
02:10:27.532 -> PM 10.0: 0 ug/m3
02:10:27.769 -> PM 2.5: 0 ug/m3
02:10:27.769 -> -----------
02:10:27.871 -> (2021-10-26T01:10:11Z) Readings saved to flash memory.
02:11:10.428 ->
02:11:10.428 -> -----------
02:11:10.428 -> 2021-10-26T01:11:11Z
02:11:10.428 -> Temperature: 22.32 C
02:11:10.518 -> Humidity: 65.21 %
02:11:10.518 -> Battery: -1 %
02:11:10.569 -> Light: 97 Lux
02:11:10.832 -> Noise dBA: 31.90 dBA
02:11:11.239 -> Barometric pressure: 101.34 kPa
02:11:11.299 -> VOC Gas CCS811: 0.00 ppb
02:11:11.299 -> eCO2 Gas CCS811: 400.00 ppm
02:11:11.299 -> -----------
02:11:11.350 -> (2021-10-26T01:11:11Z) Readings saved to flash memory.
02:11:26.670 -> Connecting to Wifi...
02:11:26.877 -> ESP finished booting
02:11:26.944 -> Connecting to Wifi...
02:11:30.709 -> Connected to wifi!!
02:11:30.981 -> (2021-10-26T01:09:11Z) Sent readings to platform.
02:11:31.219 -> Network publish OK!! (8 readings)
02:11:31.287 -> (2021-10-26T01:10:11Z) Sent readings to platform.
02:11:31.728 -> Network publish OK!! (11 readings)
02:11:31.783 -> (2021-10-26T01:11:11Z) Sent readings to platform.
02:11:32.203 -> Network publish OK!! (8 readings)
02:12:10.355 ->
02:12:10.355 -> -----------
It all seems to work good, but the PM sensor.
I think I have a faulty sensor. Any ideas?
Can you help me please?
Best regards,
Vasco Gouveia
