SCK2.3 does not connect to Wifi after lost of signal
We discovered the following error situation.
When the wifi connection went completely down there is a change the kit doesn’t pick it up again.
We then see that one blue led, of the led 3 and 4 for Wifi, is blinking and the other one, which you can see through the little glass, is off.
Also, the on/off switch is in that case not working. You cannot simply switch off the kit with this button.
You have to reset the kit to solve this issue.
Locations with a not so stable internet /Wifi see this issue often.
See anyone else similar cases?
