(1) Is possible to stream / access data on my kit to other IOT platforms, like MS Azure Cloud Platform. If “yes”, maybe some already did it?
(2) Can I use MQTT protocol to do that?
Welcome @yvl2009
That is only supported via the API
https://developer.smartcitizen.me/
In this post I explain a bit more how to do it
We also have a push API using web-sockets. However, this is only experimental
https://developer.smartcitizen.me/#real-time
Another completely different option will be to change the MQTT end-point on firmware. However, this won’t allow your device to use any of the platform features, such us the configuration tool at https://start.smartcitizen.me/
You can change the MQTT end-point here
More info on how to edit the firmware below
Many thanks!
Now using API to get the data.
By the way: I expecting to recieve Grove - Multichannel Gas Sensor v2 soon.
How can I connect it to My Smartcitizen Board? What sort of updates/setting i will need to do?
Yury
So cool you’re using the API!
https://wiki.seeedstudio.com/Grove-Multichannel_Gas_Sensor/
I don’t think we have integrated it, but we can give you support with it! Have you ever coded a bit with Arduino?
At the moment, this are the sensors supported.
Adding @victor who’s the lead firmware developer
Hi! Thanks for reply!
well, thats sad. I was sure i would be able to connect more sensors.
BTW: on the page https://www.seeedstudio.com/Smart-Citizen-Starter-Kit-p-2865.html
it was mentioned, " Onboarding new Sensors"
Any chance the kit will add support to more grove groove sensors in future?
And, what board you reccomend to use for Grove - Multichannel Gas Sensor v2 ?
Sincerely,
Yury
