I have been trying unsuccessfully to register a new device using the prompts on https://start.smartcitizen.me. It always gets stuck on the “Waiting for your Kit” prompt.
I have logged into the kit directly over serial point and confirmed various settings and everything on this end seems to be ok.
SCK > netinfo
Sending msg to ESP with 1 parts and 1 bytes
Sent part num 0
SCK >
SCK > Receiving msg from ESP in 1 parts
{"hn":"Smartcitizen3E22","ip":"192.168.0.105"}
Hostname: Smartcitizen3E22
IP address: 192.168.0.105
MAC address: FE:F5:C4:92:3E:22
ESP version: 0.9.2-a91f850
ESP build date: 2019-08-20T13:17:16Z
The network seems to be configured properly
2020-04-18T06:23:05Z
Temperature: 21.04 C
Humidity: 54.72 %
Battery: -1 %
Light: 124 Lux
Noise dBA: 45.94 dBA
Barometric pressure: 101.59 kPa
VOC Gas CCS811: 118.00 ppb
eCO2 Gas CCS811: 1178.00 ppm
(2020-04-18T06:22:05Z) Sent 11 readings to platform.
Sending msg to ESP with 2 parts and 116 bytes
␅{t:2020-04-18T06:22:05Z,55:21.01,56:55.18,10:-1,14:123,53:47.23,58:101.59,113:113.00,112:1147.00,89:15,87:26,88:27}
Sent part num 0
Sent part num 1
(2020-04-18T06:22:05Z) Published OK, erasing from memory
data seems to be published correctly. I can even ping the unit from the network and it responds to pings, but the website continues to be stuck at the “Waiting for your Kit” prompt ( https://start.smartcitizen.me/wizard/ap_final )
Are there some other settings that I should check to diagnose this problem?
