@all: Here you have a pic of the USB traces in case you need it to make the hack. I really hope it helps. Please, let me know if I there is something else I can do to help with this issue.
I glued my down using expoy (http://i.imgur.com/Au9uOtC.jpg) (Loctite 0.47 fl. oz. Five Minute Instant Mix Epoxy). Once the boards are put together, if the length is just right, you can snake it comfortable between the boards (http://i.imgur.com/dEOgxiR.jpg). Make sure the USB header is covered w/ tape or a usb thumbdrive cover so it doesnât short against anything. Also, make sure it doesnât cover the antenna on the wifly board so you donât impact reception. If everything is done right, it can actually still fit in the enclosure.
You are the man @CKCKCKCK1!
Thanks a lot for sharing your hardware fixes with the Smart Citizen community. We love to have people like you on board! Best.
@all: Thank you for sharing your experience, so I could put a big pile of glue to it before it came off!
@aitoraloa any news about the avaibility of the arduino board ? I receive my SmartCitien kit a while back and I still cannot use it :-/ I really would like to order a replacement board at a fair price and try to boot my SCK for the first time.
After waiting for almost three months to get my kit and having to pay double the price in fees in my country, I had the same problem of broken mini-usb connector.
The tutorial for repair based on super glue did not work because there was not enough space to do the soldering. I had to sacrifice a USB cable and perform the procedure suggested by CKCKCKCK1 to make the kit back to work. But it is very frustrating to see a new device that cost me $400.00 in such conditions.
I have two questions:
- Why this version of the card continues to be sold?
- Who has experienced this problem may receive a new card free of charge?
Hi @rostand. I am really really sorry to read that you had to pay extra taxes and that you are suffering the same problems that we have experience with the previous batch os SCKs, but I can promise you that we are not selling anymore the SCK version that had this issue with the USB port. Can you tell me when did you get this board!? Maybe yours was one of the last shipments we did with that batch. We do not replace the boards with broken USB ports as it should be âeasilyâ fixed but please send us an email to support@smartcitizen.me and we will see what can we do for you. By the way, have you tried CKCKCKCK1âs hack!? It worked for many users! Best.
Hi @aitoraloa
My order number is 100000153, placed on February 20, 2014.
I managed to do the CKCKCKCK1âs hack. The problem is that is a fragile connection, being only a workaround solution.
Anyway, I can not agree that the USB port problem can be easily fixed. Even if that were so, I would like to receive a kit in perfect conditions.
I will send a email to you.
Rostand
@aitoraloa My smartcitizen kit is still in its packaging and I cannot use it as the USB port fell off and I cannot fixed it cleanly. This is kind of sad as the project was inspiring on kickstarter. Is there a process for replacement of the board available ? I can send my board back to have the USB port cleanly fixed ?
Hi @aegiap, if you think that you can not fix the USB port cleanly, please, send us an email to support@smartcitizen.me with all your contact details (just to confirm the ones we have) and we will add you to the replacement boards database. Thanks a lot for your patience and sorry for the inconveniences. All the best.
Hi Aitor,
I had a similar experience.
When attempting to fit my board into the holder frame, I put pressure on the AUX connector (eg. Grove) and it came off. A loud curse was heard to leave my lips.
Luckily I have soldering skills and was able to reattach the 4 pins, but not the metal peices on each side. I have not yet tried to use the Aux port, but have some hope it will work, otherwise I am up for a replacement board, which will take weeks to come from Schenzhen. The primary function of the board is working well.
So, please take another look at this. (I realize the original post was several years back).
Weâll write Seeed Studio to take care of that issue on a general level. We will trace if there has been any change on the board assembly process. We thought the problem was already solved many months ago.
You can write techsupport@seeed.cc to request a replacement for your board.
I am a fair person.
The pressure I put on the grove socket was beyond any it could be expected to bear normally.
The darned 3d printed frame was a poor fit, and eventually I had to perform surgery on it.
So, its my fault, Iâll bear the cost.
But its better if the board could have solder thru holes instead of surface mounting.
My next step will be to look at the 3D file to see how the frame design can be modified to make it fit the board easier. I also need to make an extra frame to fit OLED and GPS boards in a layer on top. Do you happen to know anyone that has already done that work ?
I am unfamiliar with operation of Eagle softwareâŚ
The OLED is 41 mm x 41 mm (grove on one side) and the GPS is 33 mm x 41 mm (grove on the 33 mm side)
