I need to connect my SCKs to a hidden AP. However, the smartphone app only lists the public APs and does not allow adding an unlisted (hidden) AP.
Is there a way around it?
Thanks’
–Rasit
Thanks’
–Rasit
You can use the shell for passing any configuration to the device. If you are using chrome, you can use the shell there directly.
The command in questio is config:
config -mode network -wifi "SSID" "PASSWORD" -token 123456
Note that the token is not with “”. Not all parameters are needed at the same time:
config -wifi "SSID" PASS"
